Try using Chrome.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/631505-help/#findComment-8155002
8 minutes ago, colonel_mortis said:
It's a bug with Dolphin browser (as well as a couple of other, very old and non-standards compliant browsers), which will be worked around in the next forum update.
Really? I can return using only Dolphin as my mobile browsing?
I've been using Firefox for forums only since beta as Dolphin isn't supported.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/631505-help/#findComment-8155380
The only fix that I am aware of that has specifically targeted Dolphin is this one - I can't remember exactly what issues you were having, but if it was with the editor then it's unlikely to have changed. Dolphin still isn't supported by the devs, but this was a fairly major issue that some other people on other sites were very vocal about.
HTTP/2 203
https://linustechtips.com/topic/631505-help/#findComment-8155412
