So on Intel the 'k' means overclockable.
But if I don't want overclock to save money, how do I pick a mobo?
Mathresolvermajig: Intel Core 2 Duo E8400 @ 3GHZ
Framepainting-inator: EVGA GT 730
Attachcorethingy: ¯\_(ツ)_/¯
Infoholdstick: 4x2GB sticks
Computerarmor: Lenovo Case
Rememberdoogle: 2 250 Gig Drives
AdditionalPylons: Generic 300 Watt
Letterpad: Lenovo
Buttonrodent: Lenovo
Aural Interface: Sony
Liquidrectangles: 1 1600x900 Vizio TV
https://linustechtips.com/topic/631338-motherboard-and-cpu-help/
Well, you can pick a 'generally' cheaper non K CPU and use any mobo for a lower price, although getting a mobo that is cheap and doesn't support OC'ng all depends on the socket you plan to buy, e.g LGA 1150, 1151
"Hmmm, this is for sure the type of music you listen to,  if you want to lose friends."
'That last one' ??
https://linustechtips.com/topic/631338-motherboard-and-cpu-help/#findComment-8152398
So for budget would LGA 1150 be better?
Letterpad: Lenovo
https://linustechtips.com/topic/631338-motherboard-and-cpu-help/#findComment-8152400
