How to mount hard drive in linux
Solved by Electronics Wizardy,
Just now, babadoctor said:I see.
oops that command at the end should be mount /dev/sdb2
heres how it works
-sudo -s makes you root so you mount a drive(you must be root to mount)
-mkdir /mnt/hdd adds a folder that the drive will be mounted to
-mount /dev/sdb2 /mnt/hdd will mount the partition to the folder
If you want it to mount on boot add a entry in fstab
