help with computer ethernet
Cynestal
So i have a internet cable hooked up to my wifi router and it has 4 ethernet ports at the back and i want someone to tell me how to hook up the cables to from my router to the pc. i want to know if you need a female/male or female/female or male/male cable to hook those two up
Should be just a standard cat5 male to male, the same as what's between the modem and the wifi boxes.
I am a paid professional, but only when I am at work...and getting paid.
Just now, TheProfessionalAmateurs said:
It would be male/male, because the port on a pc is female, and the port on a router is also female.
Ok. thx.
cat5/6/7 will do fine, what you want is a patch cable.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
How much do like 3-5 meter cables cost?
$3-$5 give or take.
Just now, swordsman247 said:
$3-$5 give or take.
Really? Thanks
Really? Thanks
Yeah they're pretty cheap now I just give them away to customers sometimes since I have a box of them.
Well im from estonia so yea
Prices will vary based on geographic region. Here in North America, they are pretty cheap, unless you are buying from a "big box" retailer, like Best Buy, Staples, Wal-Mart, etc. They all have massive margins and high prices on things like cables.
Places like Amazon, Monoprice, and computer stores like NewEgg, NCIX, CanadaComputers, MicroCenter, etc, all have very low prices.
So, you need to find a local equivalent, or an online retailer that ships to your location.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
Hint! Check the cable, it should have 8 colored wires. That means it can handle Gigabit speeds.
If it only has 4 wires in the male rj45 connector it's a 100 Megabit cable.
That's not strictly correct. Category 5 cables (Intended for 10/100 Mbps connections) have 8 wires (4 pairs), yet there is no guarantee that they can do Gigabit.
a 4-wire (2 pair) wire is likely a Category 3 Phone Cable, and they look different, and would normally be terminated using an RJ11 connector. If someone is wiring a Cat 3 cable with RJ45, then that cable is either ridiculously old, or they are just doing it wrong.
