Razer Surround Pro changes default audio device at startup
Go to solution Solved by Murasaki,
28 minutes ago, ShadowTechXTS said:
Yes it has, no the digital audio is just some random thing, I guess I could just disable it...
Yeah, that will solve your problem :D
32 minutes ago, ModuleLFS said:
Has it always done that? Do you use this Digital Audio S/PDIF audio device?
i like linux
  • 2 years later...
This solved the problem for me!
- Basically, go to your sound settings and set razer surround pro as your default and then right click the device you want set to the default on the razer surround pro application as the default communications device; so from now on when you start windows, the designated device will always be set to that instead of the other one
-Sometimes I use the razer surround pro application for my speakers so disabling them all together wouldn't be optimal
