Hi guys
I am planning my new (small) build.
Going for this beauty of a motherboard ASUS%20Maximus%20VI%20Impact%20Mini-ITX%
(asus maximus iv impact)
and this cooler
Does anybody have an idea is there will be clearance-issues because of the risers? Changing the orientation could be impossible do to RAM-heatsinks (also since i am planing an going fanless on the cooler, i want the cooler facing the airflow.
thx
https://linustechtips.com/topic/62673-air-cooler-clearance/
link for the cooler would help, I've never seen it before.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/62673-air-cooler-clearance/#findComment-855996
Its a Prolimatech Megahalem
(L)130mm X (W)74mmX (H)158.7mm
Can't find anything about clearance with that specific board...
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/62673-air-cooler-clearance/#findComment-856003
went to bing, found this picture.
Judging by how it overhangs the heatsink on this motherboard it won't fit on the one you've chosen, the same story with the riser below the socket, you should pick a different cooler.
https://linustechtips.com/topic/62673-air-cooler-clearance/#findComment-856017
