weird humming noise when mic usb touches metal on my pc
2 minutes ago, Zebo the Zebra said:thank you the perfect answer i was looking for so theres no way of eliminate the static noise without a sound card or a an adapter and because im cheap will adapters sounds the same and i kinda like hearing myself when i unmute my mic so is there a way i could still use the usb blue yeti
As I said, reseting your sound setting to default to eliminate any boosting or anything like that might help. I'd try to turn off listening to yourself though as that might be whats causing the issue. From what I am gattering you are connecting your headset through your microphone which is connected to your pc through a USB, correct? Have you tried simply bypassing the mic? As far as I know unless you can plug your headset through your microphone there is no good way to listen to yourself without some kind of delay, so turn of microphone bosting and listening to this device in your microphone setting and see if that changed anything, if not then I would think its EMI or whatever people call it meaning you would need to use another audio solution than whats on your motherboard.
