8 minutes ago, DrJones said:
Hey guys, just wondering what thermal pastes everyone is using today. I'm putting together a water cooling loop and am trying to find out the best non-conductive paste to go on the CPU. Also what kinds are out there now, and what are their advantages/disadvantages?
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-17.html
http://overclocking.guide/thermal-paste-roundup-2015-47-products-tested-with-air-cooling-and-liquid-nitrogen-ln2/
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8050265
I started using Thermal Grizzly Kyronaut which also wins most tests. And so far I´m happy with on my CPU as well as GPU
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8050435
I use Arctic MX-4 since it's plentiful, cheap and good. It beats pastes that are more expensive.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8050702
57 minutes ago, bgibbz said:
Thanks, the benchmarks help. But what I would also like to know is what type each one is. For example metallic or silicon based and how they hold up over time, and if the cake on or are easy to remove
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8050995
Both of those articles discuss the differences and pros and cons of each.
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8052374
22 hours ago, kuramakitsune said:
ive always liked
nth1 thermal paste
i tried
MASSCOOL Shin-Etsu Thermal Interface Cooling Material G751
its labled to have a really high thermal conductivity
Yeah after reviewing the benchmarks and what they said about each, I'm probably going to go with Noctua's paste
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8063414
i have a noctua cooler and their paste is really good
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8063791
Cool, at first I thought Artic made good pastes but they each have their pros and cons. Noctua from what I read seems to be well balanced with good performance at a lower price
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8064635
2 hours ago, CiscoKid said:
Check out  Coollaboratory Liquid Pro. Not sure what to think about it, but i heard it gives best results. Not to mention its cheap. It is a liquid metal so i would be careful while working with it.
The con is:
It conducts everything :3
Welcome to the forums! And I'm not much of a fan of liquid metals for those reasons, permanent type bond and conductivity.
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8066755
I'll quote myself from another topic:
Quote
I think that those "branded" TCs are kinda "bs" if you understand me???
CoolerMaster THIS and Arctic Silver......they are all basically the same.....THING.
Some are grey, some are white....
You should all check you CPU specs in order to get an idea how HOT your CPUs can be (OCed or stock).
AMD is a furnace, we all know that. They are all like 50c stock temps.
Intel is cooler.
Man I've just OCed my CPU on 3.4GHz without setting voltage or water
cooling with "chinesse NO NAME white" thermal compound.
I only have Zalman CNPS 9500AT on 2.5 rpms......and WHITE, half-liquid paste from a local PC store which cools my cpu very nice.
Temp of my CPU right now is like 35c without doing anything special.....but when I play some game....it goes up to 50-55c.
I've tried few of those "branded" compunds......and.....no difference. Maybe 1 or 2c...
It is just marketing guys.....it is like mid-end GPU with 4GB of ram and DDR3 memory and 64bit.
That is no way that 64bit and DDR3 can push 4GB of memory.
Mark my words: "All That Glitters is not Gold".
I heard that coffee's good for my sex life.
It isn't.
It kept me awake through the whole damn thing!
I actually had to participate.
- Jeff Dunham -
https://linustechtips.com/topic/623959-best-thermal-paste/#findComment-8070486
