Best cooler for OC CPU
secendFTW
hello
i'm looking for the best CPU cooler over 100$-120$
beacause i want to OverClock my I7 4770k , what should i take
another PC have i5 4690k over 70$-90$ CPU cooler
thanks
H100i GTX
Kraken x61
EK predator for your 4770k
H80i Gtx or the x41 for the 4690k however im not sure of their current prices on the small ones.
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
3 minutes ago, z97 said:
H100i GTX
Kraken x61
thanks a lot :)
Noctua NH-D15s is probably the best air cooler. Cons with this is that it's quite large
NZXT Kraken x61/ Corsair H100i GTX are probably the best water coolers. Cons are that you need to have a place to mount the radiator and since they're aio's you also have pump noise on top of fan noise.
I would probably recommend air coolers over all-in-one water coolers
is the Noctua-D15 can fit in NZXT 410 midtower case ?
thanks
thanks
Yes but It'll be a pretty tight fit
https://pcpartpicker.com/b/7v2RsY
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
5 minutes ago, secendFTW said:
which is better noctua NH-15 or corsair h80i ?
Water will always win
besides those noctuas are a pain in the ass to install
thanks i think i will buy
NZXT 61x for i7 4770k
and H80i for i5 4690k
I recently picked up an H110i GTX for $99 for my 6800k and I'm very happy with it. OC to 4.0Ghz my temp maxes out at about 60C after 30+min of full load.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Have you even installed a noctua cooler before? The NH-D15 is better and easier to install than the H80i.
If you say so.... The h80i takes all of 2 minutes to put together. the dh15 has issues with ram clearances. And yes I have, not the most pleasant thing in the world especially when you have massive hands.
I guess the fans can be harder to clip on if the case doesn't allow much room but it's about as pleasant as dealing with tubing. The rest of installation should be the same regardless of hand size.
That's a big fat round mound of negative, partner. The H80i is a 120mm AIO, and those suck in mid tower application. Universally. Their sole purpose in life is to cool mini ITX builds that can't fit anything better and GPUs. The NH-D15 is outperformed by some, but not by much. It beats plenty.
Also, I don't know if you were trying to install your Noctua with a hammer or something, but I've installed an NH-D15 and an NH-L9i. Both were surprisingly easy.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
