corsair 200r case fans
SHADY16
so currently i am using the corsair 200r with clear side window with all my fan slots filled with 120mm fans but it can take 1 140 mm on the bottom and 2 140mm on the top, im wondering if replacing the 120's i have there would make any difference?
i7 12700k/Asus Tuf z690/32GB Corsair Dominator RGB 3200MHZ/EVGA 3080 Ti FTW3 Ultra/Samsung 980 Pro 1TB/Asus 2540x1440p 165hz Gsync/Acer 2560x1440p G Sync 144hz
If you replace the fans with 140's the temps will go down.
You could also lower the RPM of the 140s so its around the same temps of the 120mm fans.
This will result in lower noise.
Keep in mind that you should always have positive pressure in order for the pc to have as less dust as possible ;)
i have neutral pressure right now i think but i have dust filters so i should be ok
