So my friend kindly lent me his flash drive once mine had died a painful death however when I plugged it in we found out that it was write protected, I can't format it, regedit does not work and I have tried through command prompt, I have tried pretty much every method on Google and nothing works. Any ideas?
CPU: Phenom 1090T, Motherboard: Gigabyte 78LMT-USB3 RAM: Generic 8GB 1600MHz GPU: MSI Radeon R9 270 HDDs: 2 Scavenged 160GB drives (I lost my 500GB one and I don't know how) SSD: Samsung 840 evo120GB  OS: Windows 7 Case: Bitfenix merc beta PSU: Corsair CX 600W
https://linustechtips.com/topic/62231-usb-write-protected/
Try formatting it in another PC. I've had this same issue come up and using my buddy's laptop fixed it. I can't explain why.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/62231-usb-write-protected/#findComment-849633
I shall give it a go but I tried it at college as well can't hurt to try again though
https://linustechtips.com/topic/62231-usb-write-protected/#findComment-849667
No I can't see a lock, don't really want to to open the casing either
https://linustechtips.com/topic/62231-usb-write-protected/#findComment-849747
This happened to me before. I had to use some 3rd party software to unlock it and the files contained on it were a bit corrupted. I was copying data to it and all of a sudden it becomes write protected mid copy.
A few months later down the line, I figure I give that flash drive another chance and low and behold, the thing goes back into write protected mode mid copy. A 32GB flash drive that write protects around 6GB worth of data. Hate to break it to you, but that USB is a dud. Most likely it reached its write limit and goes into read-only mode for that reason. Pick up another drive, it's not worth messing with that one.
https://linustechtips.com/topic/62231-usb-write-protected/#findComment-849815
I think I was coming to that conclusion, I have already ordered another one, thanks anynway
https://linustechtips.com/topic/62231-usb-write-protected/#findComment-849879
