Okay.  I've come here, as no Google search I could think of turned up any results even relating to what I wanted.
I need to take something on the order of 40 cat 5e, (mix of solid and stranded), and extend them by about 15 feet.  An old network room was subdivided into a break space and the cables need to be run to the other half of the room.  I'm not looking to re-pull over 5,000ft of wire, but I can't seem to find a "best practice" if you will to extend them.  They are going to be coupled/spliced or whatever is recommended within a drop ceiling and then pulled into a server rack and into the back of a patch panel.
Any ideas, comments, suggestions, concerns are definitely welcome.
Thanks in advance guys.
https://linustechtips.com/topic/620198-extending-ethernet-cables/
8 minutes ago, ryan9298b2 said:
-SNIP-
For extending an existing cable that is terminated you can use a coupler like this:
https://www.amazon.com/Jadaol®-Ethernet-Shielded-Coupler-Female/dp/B01AZA4WGW/ref=sr_1_8?ie=UTF8&qid=1467531212&sr=8-8
There are also punch down versions if you don't want to termiante the ends with keystone jacks
Are the existing lines terminated on a punch down block or are they RJ 45 terminated?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Half were run straight into the switch, terminated with RJ45 and the other half were terminated into keystones and then snapped into a keystone patch panel.
Would it be okay to use 15 ft patch cables and use the coupler for the RJ45 terminations, and the existing keystones for the other half, throw it all up in the ceiling and punch down the 15' patch cables to the back of the patch panel?
I am aware that it is better to terminate to RJ45 with stranded and punch down with solid cable, but ultimately if I take my time and ensure good connections, will it really make a difference?
I personally use those RJ45 modular jack to connect solid wire. Sometimes the contractor cut the wire too short from the ceiling (just 10 cm from ceiling, I was like, you think this is f****** light?). I just terminate it to modular jack, and connect it to the patch panel using patch cord. Still going strong after few years, even I cannot access it easily anymore since it is inside a false wall. I add some hot glue to the connector and use electrical wire to make the connection stronger.
8 hours ago, ryan9298b2 said:
-SNIP-
That's not a problem ideally a single run is best as it removes the possibility of bad connections possibility for interference and all of that but if done correctly you should have no problems. For stranded you might have some trouble using a punch down connectors so for those a keystone jack may be best.
