Will a RM850 do for this build?
Solved by The Realist,
2 minutes ago, vladonizer said:I already have the 850
I was planning on having the gpu's on the preset 'OC' mode, but no more then that. and the cpu I wanted to try to push to around 4.5ghz. With a pump+res combo with 600mm worth of rad space
Just check how much "OC" mode uses wattage if its less than 200w you would be on a tight budget with power but it will do,hope this helps
