3 af120 LED or 2 AF140L
Bradders
which is best to go for, I have the 2 AF140L but wouldnt mind some red LED af120 to replace them. which has better cooling and noise
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
Well it wont matter much. Still a low quality fan. If you what a good improvement, go Noctua, fractal design venturi or be quiet silent wings 2
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
Would like to also toss on top of that: Noiseblocker fans or some Nidec Servo Gentle Typhoon fans :)
I have 3 AF120 Blue LEDs and I am still thinking about replacing them with some Enermax TB Vegas Blue fans since I am using the AF120 Blue LEDs on three Noctua LNA's (which are fantastic! Love them :))
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
2 minutes ago, Knaj said:
I have two AF140's
How are they low quality?
Well compare it too more premium ones. Like say you have tier 3 fan. What I said are tier 1 fans
Build
14 hours ago, Knaj said:
I have two AF140's
Are you referring to AF140's or AF140 LED's?  They're not the same fan and the LED version is significantly worse.
