Antec Edge 650 W vs Antec EDGE EDG650 650 W
Solved by STRMfrmXMN,
8 minutes ago, jaaa1976 said:Need buy today psu..which will be best 600-670 W fully modular psu?
I want buy custom made cables..not extensions.
I can pay more money if there is better psu..Already sold evga g2 but can try other mark..if is better
cpu i7 6700k only 1 gpu gtx 980 or later 1080-70 and sometimes will overclock cpu and gpu...watercooled pc..1 pump 4-6 fans max
You don't need a 600W-700W PSU for a single GPU system, for the record. 700W is enough for two 980s.
The EVGA G2 is likely going to be your best bet so grab that if you want a relatively cheap fully modular PSU.
