Hey Guys, Im overclocking my 4770k. Thisnis my first time overclocking and im currently running the cpu overclocked to 4.4Ghz with temps at around 65-68 with voltage set at 1.250. Im running aida64 and plan on running it overnight and just confused on one part. I set the volatage manually because the videos and articles i read said that leaving it on adapitive would over calculate the volatage and provide more than needed. So my question is then after i run this overnight and it is stable do i just then set the voltage to adaptive or leave it as is?
https://linustechtips.com/topic/615654-overclocking-4770k-help/
You can set it to adaptive.
Depending on your motherboard you might notice that the VCore voltage fluctuates (works as intended) or stays the same 1.25 (not a bad thing, nothing to lose sleep over) in CPU-Z though.
https://linustechtips.com/topic/615654-overclocking-4770k-help/#findComment-7952666
Thanks
https://linustechtips.com/topic/615654-overclocking-4770k-help/#findComment-7952693
Once all tests are done, you can absolutely set it back to adaptive.  As you read, when testing in adaptive mode can pull more voltage than what you have it set for and can cause issues.  Once you got a good, solid overclock with good temps, setting it into adaptive mode is perfectly fine.
Phanteks Enthoo Elite | Intel I9 - 7900X | Asus x299 Rampage VI Extreme | MSI 1080 TI
32Gb Dominator Platinum Special Edition Blackout 3200MHz  | Samsung 960 Pro | 2x Samsung 961 Pro (Raid 0) 256Gb M.2 SSD
Samsung 850 Pro 512Gb | WD Black 4TB | Corsair AX1200i
https://linustechtips.com/topic/615654-overclocking-4770k-help/#findComment-7952774
Keep it in manual for the AIDA stress test and burn in... when that's successfully done, then change it to adaptive based on your value. :)
Spartan 1.0
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Seidon 120XL 86.2 CFM Liquid CPU Cooler
Motherboard: Asus Maximus VI Extreme ATX LGA1150 Motherboard
Memory: Corsair Dominator 32GB (4 x 8GB) DDR3-1600 Memory
Storage: OCZ Vector Series 512GB 2.5" Solid State Drive
Storage: Seagate Desktop HDD 4TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 980 4GB Classified ACX 2.0 Video Card
Case: Thermaltake Urban S41 ATX Mid Tower Case
Power Supply: Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: LG BH16NS40 Blu-Ray/DVD/CD Writer
Optical Drive: LG BH10LS30 Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 10 Pro 64-bit
Sound Card: Creative Labs ZXR 24-bit 192 KHz Sound Card
Monitor: 2x Asus VG278HE 27.0" 144Hz Monitor
Keyboard: Logitech G19s Wired Gaming Keyboard
Keyboard: Razer Orbweaver Elite Mechanical Gaming Keypad Wired Gaming Keyboard
Mouse: Logitech G700s Wireless Laser Mouse
Headphones: Creative Labs EVO ZxR 7.1 Channel  Headset
Speakers: Creative Labs GigaWorks T40 Series II 32W 2ch Speakers
Hades 1.0
Laptop: Dell Alienware 15 2015
CPU: i7-4720HQ CPU
Memory: 16GB DDR3 SODIMM RAM
Storage: 256GB M.2 SSD
Storage: 1TB 5400rpm 2.5" HDD
Screen: 15.6" FHD Display
Video Card: Nvidia GTX 970M with 3GB
Operating System: Windows 10 Pro
Project: Spartan 1.2 PLEASE SUPPORT ME NEW CHANNEL > Tech Inquisition
https://linustechtips.com/topic/615654-overclocking-4770k-help/#findComment-7952793
