Posted June 23, 2016 I recently built a small form factor PC using an EVGA SuperNOVA B2 PSU, a SG13 case and Corsair H55 cooler. The PSU was a little longer than I expected (180mm long) and I could only make it fit by routing one of the cooler pipes around it (please see pictures). While the whole thing is "stable" and the cooler seems to be holding on, I'm worried that the pressure the PSU is exerting on the pipe will damage it or the connection to the radiator over the long term. Should I be worried at all or is the cooler going to be fine? Lian-li O11-Dynamic | i7-11700K | MSI Z590 MAG Tomahawk | 64gb Ripjaws 3200MHz | 1tb Nvme SSD + 6tb HDD RAID | Corsair H115i Cooler | EVGA 850BQ PSU | RTX 3080ti TUF | LG C2 65" & Acer Nitro XV340CK Monitor Spoiler Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 The tubing is pretty flexible. as long as it isn't kinked, which would impact performance, you should be ok. Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues. Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams. Spoiler Whaler_99 Links - "Green Machine" (watercooled), "Out of the Blue" (watercooled), My 4P Folding rigs, My multi GPU Folding Rigs, The Water Cooling FAQ, My 40TB Storage Server, My Folding Stats. The CM HAF XB review, the Aqualis Pro 450 review, the PrimoChill CTR Phase II Res review, the IcyDock ToughArmor 6x1 review, the 3x2 Storage Cage review, the 5x3 Storage Cage review, my Milwaukee Jobsite Backpack review, my Thermaltake Core X2 review, my CoolerMaster Storm Stryker overview. Link to DA Blogs home. Follow me on Twitter for updates @Whaler_99 Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951678 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 I'm not intimately familiar with that cooler, but the hoses look like proper rubber hoses. if this is the case, then what you have here will be no problem. the rubber hose will simply bend where it makes contact, and flex back to normal when it needs to and create almost no force on the connector itself. if this is NOT a soft rubber hose, but a stiffer tubing material, then yes it could be leveraging that connection which could become a problem in the future. However as it looks that doesn't seem like it would be a huge issue. You could likely it leave as is. Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951684 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 it could possibly over time loosen the tubing from the fitting causing ti to come off and leak it seems like you have lots of room to the left so what I would do is unscrew the fan+rad from there and use velcro or something to hold it in place a bit more to the left that way the tubing wont be under any stress NEW PC build: Blank Heaven minimalist white and black PC Old S340 build log "White Heaven" The "LIGHTCANON" flashlight build log Project AntiRoll (prototype) Custom speaker project Spoiler Ryzen 3950X | AMD Vega Frontier Edition | ASUS X570 Pro WS | Corsair Vengeance LPX 64GB | NZXT H500 | Seasonic Prime Fanless TX-700 | Custom loop | Coolermaster SK630 White | Logitech MX Master 2S | Samsung 980 Pro 1TB + 970 Pro 512GB | Samsung 58" 4k TV | Scarlett 2i4 | 2x AT2020 Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951686 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 That's some major kinkage. The thing is, it might be fine at room temp, but as soon as hot coolant is flowing through it and then recycling the rubber molecules are going to become stiffer then relax, stiff then relax and so on and so on. You might be fine a year from now, 2 years but any later than that and failure of the rubber pipe is totally possible through fatigue. Just try and get creative with the routing so that there's no undue tension on the tube. Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951693 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 Yeah. too much bending close to the fittings. | CPU: Core i7-4790K | Motherboard: MSI Gaming Z97 GAMING 5 LGA 1150 | CPU Cooler: NZXT Kraken X61 || GPU: Single 8GB EVGA GTX 1070 FTW | RAM: Corsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz | Case: Corsair 330R Titanium Edition Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951710 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 23, 2016 Author The hose is very flexible, so my main worry is the connection to the radiator. It looks pretty solid, so at first sight it appears to be fine, but there is a lot of pressure on it. I like the idea of moving it to the left somehow, but I plan on putting a RX 480 in there next week, so that might not be enough room to do that. Thanks for all the comments! Lian-li O11-Dynamic | i7-11700K | MSI Z590 MAG Tomahawk | 64gb Ripjaws 3200MHz | 1tb Nvme SSD + 6tb HDD RAID | Corsair H115i Cooler | EVGA 850BQ PSU | RTX 3080ti TUF | LG C2 65" & Acer Nitro XV340CK Monitor Spoiler Link to comment https://linustechtips.com/topic/615573-question-about-mini-itx-build/#findComment-7951726 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
