Power Draw
Go to solution Solved by AWinchester,
i think i will just go with an 850 watt appreciate the help
hey guys just planning a build here
the pascal cards are really efficient and not as power hungry as the maxwell cards so i was planning a build using 2 1080's in sliand im'm kinda syuck on what power supply to buy i was going to go with a 1000 watt P2 from EVGA but seeing the efficiency of the new cards i dont if i should go with a 850 watt psu
suggestions anyone???
i want to overclock and try to hit a stable 2.1 GHz on the gpu's and somewhere in the ball park of 4.4 GHz on my cpu or as far as i can get on both things
i will be using 2 EVGA FTW 1080's and a 6800k on the asus x99 deluxe 2 mobo
https://linustechtips.com/topic/615106-power-draw/
1000W is ridiculously overkill and even 850W is still too much.
I wouldn't be surprised if you could run that rig on a 650W PSU.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/615106-power-draw/#findComment-7945443
4 minutes ago, ENiX said:
So here is the thing. I'm running two Xeon E5-2670's 8x HDD a gtx 570 and a GTX 780 and I have never seen above 600 Watts used via the monitor on my AX1200i.
I can't image you would have a problem with a 850 watt PSU.
are you running stock clocks and no over volts or do you have any OC's
sorry if im overly cautious im kinda new to this overclocking i've tried it before but this is going to be my first OC and custom water cooled build
https://linustechtips.com/topic/615106-power-draw/#findComment-7945444
http://outervision.com/power-supply-calculator
Plug in the settings you plan on using and see what it says.
https://linustechtips.com/topic/615106-power-draw/#findComment-7945510
it gave me 810 watts with the core clock on the gpu's at 2139 with no oc on the memory and the cpu at 4.4 ghz at 1.3 volts
https://linustechtips.com/topic/615106-power-draw/#findComment-7945597
Keep in mind that's a worse case scenario number that takes into account 10% capacitor degradation for x years.
So you would definitely be safe with an 850 Watt PSU
https://linustechtips.com/topic/615106-power-draw/#findComment-7945609
Power supply calculators are basically random number generators, third-party reviews and benchmarks are better sources for determining how much you need. I seriously doubt it'll even reach 600W under full load and for the overclocks you're aiming to go for.
https://linustechtips.com/topic/615106-power-draw/#findComment-7945794
I see that calculator here all the goddamn time, it's not good. It wildly overestimates how much power systems use.
A 750W EVGA G2 is fine for you with tons of overclocking headroom.
https://linustechtips.com/topic/615106-power-draw/#findComment-7945947
I have never seen any of my single GPU builds go over 230W (and these had at least i5's and just below flagship GPUs). And an SLI build I had pulled about 330W from the wall.
So give or take, 450W is the minimum as long as it's a great quality supply.
https://linustechtips.com/topic/615106-power-draw/#findComment-7946392
