Posted June 22, 2016 Hi one and all! I have a question. I have a "stock system" not currently overclocked and no requested overclock by the builders But somehow my CPU clock speed is just shy of 4 mhz when the base clock is 3.6 mhz? Possible or have the builders (PC Specialist in the UK) pre overclocked the CPU? Or is the Turbo boost active and I've no idea? Processor 1 ID = 0 Number of cores 6 (max 8) Number of threads 12 (max 16) Name Intel Core i7 6850K Codename Broadwell-E/EP Specification Intel(R) Core(TM) i7-6850K CPU @ 3.60GHz Package (platform ID) Socket 2011 LGA (0x2) CPUID 6.F.1 Extended CPUID 6.4F Core Stepping Technology 14 nm TDP Limit 140.0 Watts Tjmax 100.0 °C Core Speed 3999.9 MHz Multiplier x Bus Speed 32.0 x 125.0 MHz Stock frequency 3600 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 6 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 15 MBytes, 20-way set associative, 64-byte line size FID/VID Control yes Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Turbo frequency is 4GHZ. Don't worry about it. Quote # of Cores 6 # of Threads 12 Processor Base Frequency 3.6 GHz Max Turbo Frequency 4 GHz TDP 140 W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 3.8 should be all core boost. 125MHz strap with a 32 multiplier is 4GHz? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Author 1 minute ago, DEcobra11 said: No, 4 GHz is one of the turboboost states Ah ha! 1 minute ago, Rune said: Turbo frequency is 4GHZ. Don't worry about it. You guys at least confirm what I semi thought, thanks guys Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Author 1 minute ago, Yamoto42 said: 125MHz strap with a 32 multiplier is 4GHz? HI, can you explain the question further? Cheers Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 I'd just expect to see a 36 or 40 * 100MHz...not a 32*125MHz. What's your memory running at? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Author 2 minutes ago, Yamoto42 said: I'd just expect to see a 36 or 40 * 100MHz...not a 32*125MHz. What's your memory running at? This is what I found on the memory DIMM # 4 SMBus address 0x54 Memory type DDR4 Module format UDIMM Manufacturer (ID) Corsair (7F7F9E00000000000000) Size 8192 MBytes Max bandwidth DDR4-2133 (1066 MHz) Part number CM4B8G2J3000K15K Nominal Voltage 1.20 Volts EPP no XMP yes XMP revision 2.0 AMP no Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 2 minutes ago, imaner76 said: This is what I found on the memory DIMM # 4 SMBus address 0x54 Memory type DDR4 Module format UDIMM Manufacturer (ID) Corsair (7F7F9E00000000000000) Size 8192 MBytes Max bandwidth DDR4-2133 (1066 MHz) Part number CM4B8G2J3000K15K Nominal Voltage 1.20 Volts EPP no XMP yes XMP revision 2.0 AMP no That is just the JEDEC + SPD information. That does not tell us what it is currently running at. However, judging by that nomenclature of the ram itself, I am going to assume you have 3000mhz ram. If you loaded the XMP profile, the CPU strap will automatically change to 125. This is where your 4ghz comes from. My (incomplete) memory overclocking guide: Does memory speed impact gaming performance? Click here to find out! On 1/2/2017 at 9:32 PM, MageTank said: Sometimes, we all need a little inspiration. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Author 2 minutes ago, MageTank said: That is just the JEDEC + SPD information. That does not tell us what it is currently running at. However, judging by that nomenclature of the ram itself, I am going to assume you have 3000mhz ram. If you loaded the XMP profile, the CPU strap will automatically change to 125. This is where your 4ghz comes from. Yep, sorry for the miss information, it's the Corsair Vengeance DDR4 3000 MHz. So the CPU will jump speeds when paired with that speed of RAM? Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 It's caused by the memory running at XMP. Just lower your multipler until it does back to 3.6GHz by multiplying it with 125MHz. Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64 HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64 HP Envy x360 BP series Intel 8th gen AMD ThreadRipper 2! 5820K & 6800K 3-way SLI mobo support list Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Wait 3.99 Mhz? Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples: Do this: Quote And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor! Or this: @DocSwag Buy whatever product is best for you, not what product is "best" for the market. Interested in computer architecture? Still in middle or high school? P.M. me! I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that. Compooters: Spoiler Desktop: Spoiler CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync) Home Server: Spoiler CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter? Laptop (I use it for school): Spoiler Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050 And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2016 Author 2 minutes ago, DocSwag said: Wait 3.99 Mhz? Am I having issues? Spoiler Eyeballs: HTV VIVE - AOC G22460PF 144htz FS Ears: Logitech G933 - Logitech Z901 Case: CORSAIR CARBIDE 600C CPU: Broadwell-E i7 6850K cooled by Corsair H80i GT Hydro Motherboard: ASUS ROG STRIX X99 RAM: 32GB Corsair Vengeance DDR4 3000 MHz GPU: NVIDIA GEFORCE GTX 1080 Storage: 1TB Samsung 850 EVO 2.5" SSD & SATA 6Gb PSU: CORSAIR 850W RMx Fingertips: Logitech G810. G700s, Fanatec ClubSport Wheel Base V2, ClubSport Steering Wheel Universal Hub, Wheel Rim GT, ClubSport Pedals V3, ClubSport Shifter SQ V 1.5 . Bottom: GT OMEGA STEERING WHEEL STAND & REAR SEAT FRAME with GT OMEGA RACING RS9 SEAT + SLIDERS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
