First, forgive me if this is the wrong section.
Ok well I was just wondering if anyone has used dry ice to cool a cpu?
I might be trying it and was looking for tips.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/61375-dry-ice/
You can but it's more fore extreme cooling. You'll need a pot for it though.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/61375-dry-ice/#findComment-836371
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/61375-dry-ice/#findComment-836374
Umm I know dry ice is -78 degrees, I don't know if cpu and coldness have any problems?
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/61375-dry-ice/#findComment-836376
It's only for extreme overclocking. It should never be used on a day to day basis.
https://linustechtips.com/topic/61375-dry-ice/#findComment-836377
dry ice is a solid gas, which means once it touches heat it wil evaporate
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/61375-dry-ice/#findComment-836414
Just something to play around with and see how high I can get some old cpus and a few newer ones :P Nothing permanent
https://linustechtips.com/topic/61375-dry-ice/#findComment-836439
Would not recommend using dry ice unless you know what you're doing.
Desktop: Intel i5-3570K (stock) | Asus Sabertooth Z77 | G.Skill RipJaw 16GB 1600MHz | Samsung 840 120GB | EVGA GTX 680 SC+ 2GB | Fractal Design R4 | Windows 8 Pro (soon to have dual boot Mac OS X)
Retina Macbook Pro : Intel i7-3840QM | 16GB 1600 MHz | 256GB SSD | Nvidia GT 650M 1GB | Mac OS X 10.8.5
https://linustechtips.com/topic/61375-dry-ice/#findComment-836451
Go ahead, using old CPU's and overclocking on them with LN2 or dry ice is fun and gives a general feel of the situation and how everything must be done
https://linustechtips.com/topic/61375-dry-ice/#findComment-836452
Have you done it before?
https://linustechtips.com/topic/61375-dry-ice/#findComment-836456
Practiced on a 775 platform before going to an AM3+.
https://linustechtips.com/topic/61375-dry-ice/#findComment-836462
Anything I should worry about or be careful of? I know the normal things like layered clothes and thick gloves, goggles .etc..
Anything else though?
Think you could walk be through it or tell me what I need? :)
https://linustechtips.com/topic/61375-dry-ice/#findComment-836476
Carbon Dioxide? Keep A/C and airflow regular in your lab and don't breath in too much of it.
https://linustechtips.com/topic/61375-dry-ice/#findComment-836485
LAB?!
Will a basement be ok or should I use my garage
https://linustechtips.com/topic/61375-dry-ice/#findComment-836503
LAB?!
Uhhh does it have good airflow?
https://linustechtips.com/topic/61375-dry-ice/#findComment-836510
Well not really,im guessing my garage will be best with some fans venting the air out
https://linustechtips.com/topic/61375-dry-ice/#findComment-836531
The cooler the better. People even use liquid nitrogen sometimes.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein
https://linustechtips.com/topic/61375-dry-ice/#findComment-837133
I have used dry ice on my radiator with. I put the radiator with fan in pull and the dry ice on the side that had no fans and yes the temperatures did drop significantly but it was just to see how it would work and i only did it that one time.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/61375-dry-ice/#findComment-837255
