Overclocking Affect on Power Consumption
Solved by Energycore,
2 minutes ago, Mr. Tsao said:What is the average affect overclocking has on the power consumption of a GPU, specifically the new FinFET cards such as pascal and polaris (obviously info on polaris is limited)
Hi! There's an equation that estimates differences in power consumption when overclocking. It goes like this:
P1: Stock Power
P2: OC Power
V1: Stock Voltage
V2: OC Voltage
C1: Stock Clockspeed
C2: OC Clockspeed.
So then to estimate OC power, we use the equation:
P2 = P1 * (C2/C1) * (V2/V1)^2
For Stock Power numbers, refer to reviews of the graphics card you've got.
Forum: If the equation isn't quite right feel free to correct.
