Hi Guys,
I’ve had my PC for around 3 years and when I first got it, it was a great mid-range machine. However with the new console generation and more demanding games it is struggling to play them. I am struggling to figure out whether I can upgrade it or whether I should just start from scratch.
My current setup is:
CPU:
AMD Athlon X4 750K OC at 4GHZ
RAM:
8GB DDR3
Graphics card:
Sapphire AMD Radeon R7 250 2GB
Motherboard:
Gigabyte GA-F2A88XM-DS2
Hard Drive:
1TB
Operating System:
Windows 10 Home (64-bit)
Case:
Unknown
PSU:
Unknown
The new system I am looking at, which costs around £900:
CPU:
Intel Core i5 6500
RAM:
8GB Crucial 3000mhz DDR4 (2x4GB)
Graphics card:
Asus Turboforce GeForce GTX 970 4GB
Motherboard:
Gigabyte Z170-Gaming K3
Hard Drive:
Samsung 250GB 750 Evo SSD
Second HDD:
2TB S-ATAIII 6.0Gb/s
Operating System:
Case:
Corsair Carbide Spec-01
PSU:
550W Corsair VS
Any help would be very much appreciated.
-Luke
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/
4 minutes ago, Sutty279 said:
Hi Guys,
CPU:
RAM:
8GB DDR3
Graphics card:
Motherboard:
Hard Drive:
1TB
Operating System:
Case:
Unknown
PSU:
Unknown
CPU:
Intel Core i5 6500
RAM:
Graphics card:
Motherboard:
Hard Drive:
Second HDD:
Operating System:
Case:
PSU:
550W Corsair VS
-Luke
Fresh start, but scrap that 970, Pascal's out and you can get more performance
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927150
Wait, you're not looking at a pre-built are you? If you are then just get that since you would probably be spending a lot more money for a 1070 pre-built, but if you are building it yourself I would definitely go with a 1070 vs the 970
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927158
Alright thank you :)
Do you have any advice for building a machine which is more future proof?
Definitely dont go for that PSU. VS series is prety bad.
Go with new CX (they have grey stickers .. the one with green stickers are terrible). Or go with EVGA B2, GS, G2.
And as was mentioned .. dont go with GTX 970, go with RX480 once it comes out or with GTX 1070 if you get enough money.
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927167
I was looking at a site called DinoPC, they have pre-built PC's but you can customise and configure them. A friend has used them before and they are really good.
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927185
Building your own is always better, unless you happen to really like the aesthetics and/or don't have the experience to build your own. Hey, but this coming from a 13 year old so take everything I say with a grain of salt
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927196
I have some experience building but its just the effort really, these guys do it all for you and it only costs a small amount more than doing it yourself. Plus you get a 3 year warranty on labour.
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927209
If that's what you want then go for it, I am only 13 after all and what do I know? I haven't even built a pc before(though I have disassembled my laptop a few times before and did stuff with it and also know all the steps for pc building). If you think it's a good deal then you should get it, good luck to you.
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927231
Cheers for the help :)
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927236
Go for Intel. AMD has a lot to prove.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927256
The AMD build is his current system.. :P
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927309
That CPU looks alright but if you wanted to you could upgrade to an 860K, top up on RAM and get something like an R7 370. Then maybe get an SSD instead of a Hard drive. That should keep you up to date. Good luck :)
Oh, can't forget the PSU if it is something crap...
Edit: If you are to get the 860K then you may need to update the bios before hand.
IT Manager working in the Education sector.
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927434
This leaves you 325 pounds for your GPU.  You are looking at three choices for a GPU right now (not used, new units):  The RX 480 launches on the 29th, the GTX 1070 and the GTX 1080.  Don't buy anything else.  A used GTX 980Ti could be an option.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£166.96 @ More Computers)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  (£46.49 @ Amazon UK)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£49.49 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£74.99 @ Overclockers.co.uk)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  (£50.38 @ CCL Computers)
Power Supply: SeaSonic EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£70.99 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (£71.90 @ More Computers)
Case Fan: be quiet! Pure Wings 2 61.2 CFM  140mm Fan  (£7.99 @ Novatech)  <<Front intake
Total: £573.16
Generated by PCPartPicker 2016-06-19 17:44 BST+0100
https://linustechtips.com/topic/613445-upgrade-or-start-fresh/#findComment-7927483
