Fire strike stress test - cpu frequency question.
Hello. Like we know 3dmark was updated to Fire strike stress test mode. I bench using Fire Strike stress test ULTRA on my 980 Ti Gaming Xtreme and 6700k on stock. Result are normal.
My screen, take a look on cpu frequency ( 4 to 4,2 ghz ):
https://postimg.org/image/pqpkrehhz/
But cpu frequency during test is drifting between 4-4,2 ghz i dont know why. Is this normal?
Somebody make test Fire Strike Stress test and he get stable 4,2 ghz.
http://videocardz.com/61107/futuremark-releases-3dmark-fire-strike-stress-test
I'm not sure, to be more sure, are you overclocked?
M1 MacBook Air 256/8 | iPhone 13 pro
3 minutes ago, zzz123 said:
No all is stock.
Then it's normal. Your CPU runs at 4ghz turbo.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
2 minutes ago, zzz123 said:
But why sometimes it goes down to 4 ghz and up to 4,2ghz and again down during test.
And why somebody here have stable 4,2ghz .:?
https://postimg.org/image/69by30qdt/
your cpu is doing what it should, turboing up and down, while their cpu has turbo boost disabled, your cpu runs at 4ghz, but is at the right opportunities going to 4.2
For the 6700k, it boost to 4ghz when using 2~4 cores, but 4.2ghz when only a single core is on. Those spikes are likely to be loading sections, which the cores aren't being stressed (and thus you get a boost).
As for the stable test, the guy just set his CPU to run at 4.2ghz even on 4 cores load. You have to set it up, though, that's not the stock behaviour.
it's going 4.2GHz when only one core is loaded, usually during scene switching, that's why it's so periodic
you are completely fine
all you need to be worrying is the GPU load and the final result - consistency mark
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
1 hour ago, zzz123 said:
But in other tests in 3dmark i have 4,2 ghz no matter what without changing to 4 ghz. Any ideas? Only in stress test my clock is drifting between 4ghz to 4,2ghz
Those tests stress the CPU differently.
Simple, if you want constant 4.0Ghz, go in BIOS and disable turbo boost.
If you want constant 4.2, 4.3, 4.4, 4.5, etc... Ghz, disable turbo boost and overclock it to that speed.
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
