Hello
I'm new to computer building.  I just built my new computer based on guides I watched from linus tech tips.  I have a 6600k on a EVGA FTW board.  No GPU yet (saving up).  Everything installed and worked without a hitch....but after a week my computer has started to lock up completely.  Usually when watching youtube/twitch.  I want to fix this myself, but I don't even know where to begin.  There is no log or blue screen that happens.  The computer just completely locks up and you can't type/move mouse or anything.  I have to hit the reset button and start over.  The computer doesn't seem to know it crashed either.  Once it loads up it's like nothing happened.
My only question is, what would you all do from here?  How do you go about diagnosing this without anywhere to start.
Thanks for any help you can give.
-Pond
https://linustechtips.com/topic/611298-i-need-help/
what PSU do you have
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/611298-i-need-help/#findComment-7904061
Any OC?
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
https://linustechtips.com/topic/611298-i-need-help/#findComment-7904169
6 minutes ago, Pondskipper said:
I have both hwmonitor and openhardware.  Nothing is out of the norm.  even under load it doesn't get high.  I have the CPU water cooled with an h80i and several fans.
What temps specifically?
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/611298-i-need-help/#findComment-7904190
Try several different browsers (Edge, Firefox, Chrome and Vivaldi) and see if it still happens. If it only happens with one of the browsers, then you can start to diagnose further from there. As far as I know, Twitch still uses Flash for video and hasn't updated to HTML5 yet, so make sure your Flash is up to date. YouTube should switch to HTML5 if Flash is disabled/not installed. Make sure your iGPU drivers are up to date as well.
Since it's a relatively new build, a reinstallation of Windows wouldn't be a bad idea.
https://linustechtips.com/topic/611298-i-need-help/#findComment-7904209
moved to troubleshooting
https://linustechtips.com/topic/611298-i-need-help/#findComment-7904247
