1 minute ago, Evann said:
Hi,
so i built my PC yesterday - and in my opinion the Case Fans are way to loud.. i have the Phanteks Enthoo Evolv ATX with  PH-F140SP FANS...
I set them in BIOS to run at 10% (via PWM hub) ... but i still think theyre way to loud, is that normal?
How are your temps?
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897274
check your gpu then
Elemental
Laptops
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897288
In bios put your fans to minimum and on your PWM
Elemental
Laptops
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897305
2 minutes ago, Evann said:
what do you mean with minimum... 1%? :D
I guess, try that xD
Elemental
Laptops
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897313
modern fans can take a "complete stop" just fine, just put your finger on the individual fans to *GENTLY* slow them down to a stop, that'll single it out to a single one, all, or none at all.
you mentioned an AiO watercooler, are you sure its not the pump you are hearing?
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897366
yea.. that could also be... but its really weird... (its my first AiO).. it makes a crackling sound.. now i plugged the pump out.. and i can still hear it.. way quieter but its still there...
Listen to that..
IMG_3094.MOV
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897463
If I remember correctly, the stock case fans aren't pwm and you should control them with dc.
https://linustechtips.com/topic/610674-loud-case-fans/#findComment-7897490
