it can handle skyrim. i guess. my friend's GT630 can handle it.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828362
http://pcpartpicker.com/p/1IQaG
this one would play at high/ultra settings on 35
and its only 20$ more. if you dont think its worth it... then you must be from mars my friend.
and it will play any other modern game also... on mid settings at 30+ fps easily
yes this will also destroy skyrim +  2 times bigger storage
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828380
It's funny how everyone created pretty much the same build on pcpartpicker. All with the same CPU, Mobo, GPU by XFX. lol
http://pcpartpicker.com/p/1IQd6
Get a 500W PSU though, you can reuse it for future builds, the CX430 though might not power a powerful build in the future.
who cares...
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828389
How about this one? Cheaper and better performance:
http://pcpartpicker.com/p/1IQfF
  • Primary PC: i7-3770K@4,6GHz | Thermalright Macho | ASRock Z77 Extreme 4 | 16 GB Corsair Vengeance@1866MHz | 2x Gigabyte 660ti 3GB@1130MHz | 256 GB Samsung 840 | WD Black 1TB | BeQuiet! DarkPower Pro 650W | Zalman Z11
  • Secondary PC: i7-860@3,1GHz | Scythe Katana 3 | ASUS Maximus III Formula P55 | 8GB Corsair Vengeance 1600MHz | 2x Zotac GTX 280@650MHz | WD Velociraptor 500GB | Seagate Barracuda 2TB | BeQuiet! DarkPower Pro 750W | Coolermaster Cosmos S
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828399
Copy-paste link. I didnt choose xfx loL :D
Cpu is... horrible. Skyrim is intensive on cpu, but i do agree on that 7790 ! GOod deal, lets russle sumtin up with better cpu and 7790 ! This will be one beast computer.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828412
VOILA ! This build will play Skyrim maxed out. Have fun :)
Motherboard:  Gigabyte GA-F2A85XM-D3H Micro ATX FM2 Motherboard  ($62.99 @ NCIX US)
Memory:  Corsair XMS3 4GB (1 x 4GB) DDR3-1333 Memory  ($29.99 @ Newegg)
Video Card:  Sapphire Radeon HD 7790 1GB Video Card  ($109.99 @ Newegg)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($90.88 @ Amazon)
Total: $438.81
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-09-29 08:30 EDT-0400)
OP i am waiting on feedback. I can cut off 10 bucks less for MSI board if you are on extremelly tight budget.
This build destroy the original you posted. If you want furthermore cheaper build then 7770 is the way to go.
http://www.youtube.com/watch?v=EpYJfjXnQmc Gt640 is nowhere to be seen :)
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828439
cmon man ,where is the OS ? if i remove it i can do a better build too. and the cx 430 can hold a gpu like 7870 so no problems there.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828442
http://pcpartpicker.com/p/1IQzD
It's a bit over budget but with a quad core cpu
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828498
Damn, people usually don't ask for OSs so i didn't include it. By the time i configured the build i already forgot that he wanted one. :D
A really good upgrade from this build would be a 4670K or FX 8320 plus a HD 7950 or R9 280 and i doubt that a cx 430 could handle it.
who cares...
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828546
all recommended cpus are quads. that is a bad build. apu with dedicated gpu ? no sir
Did you see Tek synicates videos of a apu with a 780 only when you go above 1080 do you start to bottle neck the performance
or on very cpu intensive games.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828585
that apu you choosed,is on FM1 ! the cpus that we recommend are the same cpus found in apus today,5800K,6800K BUT without the integrated GPU . because there is no need,not even one to get an apu if he will buy a dedicated GPU . do you understand ?
https://linustechtips.com/topic/60887-low-budget-build/#findComment-828700
If you pick the right GPU you can Crossfire it with the APU. Which would tear Skyrim apart.
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-843134
If you are going to pick an Athlon, get the new ones (Richland, FM2 socket). And if you want to be possible to upgrade in the future, get an FM2+ mobo, they have started to sell them already, meaning you can upgrade to Kaveri / Carrizo when they launch.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-846309
Total: $438.81
Great list, exactly what I would have chosen.
Go for this.
https://linustechtips.com/topic/60887-low-budget-build/#findComment-846353
I built my friend one, went with a Sempron 145, ASRock N68C-GS FX (I think), and a Radeon HD 6970 (his idea, not mine), and it does well with it. Mine is almost the same EXACT setup, but with a HIS IceQ Radeon HD 6570 instead of the reference 6970, and it does well.
EDIT: I know right now my sig goes against my rig, but I just built this last weekend
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/60887-low-budget-build/#findComment-848095
