GTX 1080 + DP to DVI then DVI to VGA. Nvidia control panel reads the monitor, but wont display anything.
Solved by TrigrH,
11 minutes ago, DarkBlade2117 said:Off-Topic.
But why a GTX 1080 and a fucking VGA monitor??
it was starting to bother me that the gtx 10 series had DVI at all, let alone wanting to use vga...
Anyway corsairian you need to buy a DP to VGA adapter as the DVI ones don't carry the anolog signal (so the don't work.)
You can use the other adapter on the DVI port and plug the main monitor in the DP port with your new adapter.
