thermal paste vs. thermal adhesive: performance difference
I know you are not supposed to use thermal adhesive between the CPU and the heat sink. However I like to do something similar because there is no other way.
Therefor I'm interested in the performance difference between thermal paste and thermal adhesive (Arctic Silver Premium). The adhesive has about 7,5 W /(m*K), paste can range from 5 to about 11 W(m*K) so they should perform more or less the same.
Has anybody by accident glued the CPU to the heat sink and has some experience with the performance?
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
I haven't had personal experience comparing the two but there shouldn't be much of a difference. The important part is that the paste and/or adhesive fills the gaps that would otherwise be air which is much worse at transferring heat.
That's waht I thougth, but I have no experience / proof.
Also the glue will displace mineral oil and not air.
yeah, you can use toothpaste for thermal compound and it'll work pretty close to thermal compound for a short while, so as long as you're using a product designed for this kind of thing it'll work just fine
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
The idea is to minimised heat conduction resistance. So the paste and pad is to fill in the gab between cooler and cpu plate. So less gab is better.
And comparing pad and paste.
Is small gab paste better. For bug gap, pad can fill in more firmly. So depends on size of gap.
With an overclocked Titan X and passive cooling, I can not afford to waste some performance to a bad thermal compound. I'm already on the edge ;)
I have only a smal gap, so I don't need a pad. But I'm wondering between the performance of thermal past and glue.
tested differences in paste/pads is a few degrees, that's the low end to top end so if you get good pads you're looking at a degree or two from good thermal paste
desktop
HTPC
The temperature difference is dependet on the thermal conductivity of the paste / pad, but also on the thickness, area of the heat transfer and the power that is going througth the connection. So My results can vary considerably from an other test with other parameters.
But I got your intention, with the high quality termal adhesive I should be fine.
If you're worried about temps on the GPU whilst being passive, just use CLU.  It will have the best delta's, I just put it on a 780 Lightning to test last night, and saw a 3c drop on watercooling under load. My room was 18c and I was seeing load temps hover at 23-24c in Valley at 1.287v 1332 mhz.
Just be careful when you put it on, it only takes like a minute or so, very easy if you just take your time.
I think the issue with a pad may be it's too thick, and some of the heat transfer could be lost? I'm not sure if the pad would melt or anything under conditions on top of a gpu, I've never seen anybody do it before so IDK.
Liquid metal in a mineral oil pc is a bad idea. It might leak out and get to other components.
It's fairly solid when  you put it on, I think it'd be OK.  Not 100% sure though, what did Linus use in his build log? Normal paste?
Liquid metal is very agressive towards aluminium. As my heat sink is made out of aluminium, it's going to be funny.
O I didn't see that part :P
