Question about fans RPM
IcEWoLF
I noticed when I have the front cover plate - which is usually used to dampen the sound of the case I noticed that the fan RPM slows down slightly, is this normal?
42 minutes ago, IcEWoLF said:
i think its just because your temps are better because you have less load. if this isnt an advertised feature on your case the fan controller doesnt know if the cover is on or not.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
If your fans are 3pin ones, there's always some fluctuation in RPM. No, having front panel or not doesn't have any effect on that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Nah these are 4 pins: http://www.newegg.com/Product/Product.aspx?Item=N82E16835352024
Its inserted through a PWM Y Splitter cable to the mobo.
I also noticed that the bottom fan blows little more air than the top fan, but when I remove the cover it blows the same amount of air the bottom one is.
I think its just the front panel design.
PWM fans follow temps better so thats a thing. And you are right on last part. Case has only so many and such located ventilation holes.
Yes, it's normal. Case fans don't normally compensate for resistance to maintain rpm.
