Internet over Power kinda works
Ace0100
Hi guys
My cousin bought a new computer and he has setup internet over power adapters because he does not have a wireless USB adapter. The internet over power works on his old computer but when he connects the cable to his new computer it does not work any ideas on how to get it working.
Thanks
CPU: i7 3770 3.40Ghz 3.90Ghz II  Motherboard: Gigabyte II Ram: 16GB Corsair Vengeance II GPU: Gigabyte GTX 970 G1 Gaming Edition II Case: CM Storm Enforcer II
Storage: Intel 240GB SSD, 2TB HDD, 4TB SSHD II PSU: Thermal Take 700w II
Madness, as you know, is a lot like gravity, all it takes is a little push.  ~Joker
2 minutes ago, Ace0100 said:
Hi guys
Thanks
is he on the same circuit?
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
yes he is one story house and i am doing the same thing but i am on 2 circuit but seems to work
welp its above me then. usually when powerline doesnt work its because its on 2 different circuits.
it works on his old computer i find it odd tho his going to send me specs/model of what adapter his using i told him to try to re sync them with the new computer plugged in waiting on reply from him
powerlines do work on seperate circuits because theyre usually on the same phase, i know from personal experience, on his new computer, does he have the ethernet drivers installed?
plus if he lives in the same house where is old computer worked, why wouldnt his new one work?
Can he test if connecting to the network not though the powerline (connect it to the router) does or doesn't work.
If it does not work it will be to do with the computer's NIC. (Re)install drivers or try a different one.
If it does i'm not sure, test the cables?
What are you looking for?
Just now, Hans Christian | Teri said:
Did he remember to install the driver for his NIC?
I am getting him to test it with out the adapters direct connection
Update: He directly connected the computer to the router and it works but still wont work with the adapter but the adapter works with the old computer
Are there any drivers for the powerline adapter? I highly doubt it but it's worth checking out.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
nah no drivers for it just plug and play
What model powerline adapters does he have? Just curious if anyone else has had a similar problem with that model.
Prior Build Log/PC:
Its a D-Link AV 500
3 minutes ago, Ace0100 said:
Its a D-Link AV 500
So it looks like that model only does 10/100 Mbps, although I doubt it could he have set the properties on the new computer to 1000Mb Full Duplex? If you have him open up the Network and Sharing Center > Adapter Settings > Right click on the NIC > Properties > Configure > Advanced > Speed and Duplex. From there check if it's set to Auto or not.
Prior Build Log/PC:
yea its on auto Negation and the power light and the computer icons are on the home light is not
Ok guys so i went into the speed and duplex and changed the value from auto to 100Mb it works now but slow as hell
