Building a Workstation!
Go to solution Solved by rafazafar,
21 minutes ago, BozurK said:
Hello there everyone,
My friend is planning to build a Workstation system and he is going with the Intel Xeon E5-2640 v4 but, there is a confusion about the motherboard right now...
Please, suggest us a decent motherboard for that CPU
- Thank you :)
Well.. im using a 2698 v4 on a x99e-itx. works like a charm :)
But you cant go wrong with any x99 in general. Its more of what you want from the motherboard like pcie lanes, kvm, lan, ect2.
Its hard to recommend any without knowing what you actually need.
- Thank you :)
"Being a true gamer is what keeping me away from social life, and forgetting about the world's bullsh*t"
https://linustechtips.com/topic/606398-building-a-workstation/
you really can't go wrong with the X99-ws
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853860
Hey bro,
Alright but my friend would like to go with a dual socket motherboard and he is curious if 1 CPU would boot the system and the second CPU would be optional to Install as of now.
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853866
1 minute ago, BozurK said:
Hey bro,
I believe it would work fine
some of the ram slots wouldn't be usable though, since those are piped through the 2nd CPU
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853872
3 minutes ago, BozurK said:
Hey bro,
if you can find one and he is willing to pay the price then yes that would almost certainly work but keep in mind you will need one hell of a case for that if you are not going to be using something like a 3U server rack chassis
Builds:
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853882
Are you sure that it would boot up and works just fine? because he has to confirm it before getting the motherboard.. :)
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853887
yes, it'll work
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853888
- Thank you :)
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853901
Okay got'cha
Thanks!
https://linustechtips.com/topic/606398-building-a-workstation/#findComment-7853911
