radiator fan died
Wydz
H110i GT
1 of the inside fan on my rad died, but other is working.
my temps are 23-27c at idle (6600k) which is the same with all 4 fans on the rad working.
should i be worried until my replacement comes in or am i fine?
No, if you are running push/pull, you could probably lose half your fans and still not notice much of a difference
i think thats what i have?
top of case > fans > rad > fans > inside of case
yes, even one layer of fans would work fine
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
yes, that's push/pull. :P Even with 3 of 4 not working, it would probably be OK - you would basically just have an H60 in that situation
okay thanks for the calm mind guys, i have one ordered just because my ocd would run wild knowing i only have 3/4 fans working.
i wont rush the replacement then :)
wut
3 minutes ago, josephaltareb said:
wut
It's an approximation :P
Think about a 240 mm rad with only a single 120 mm fan on it.  It would basically be as effective as a 120 mm rad in that case.
you probably know this but the h110i gt is a 280mm rad ;)
if 2 fans were on there then the perf is there as expected (I PERFER PULL)
let alone 3.
eh, there is a little higher perf because there is more space dissipated.
let alone 3.
I was saying if only 1 fan on the H110i was working (if 3 of 4 were not working).  And like I said, approximation :)
Yeah.  Approximation! :P
i think you got it mixed up boi.
I'm aware OP has 3 of 4 working.  I was just providing an even more extreme example to set them at ease.
ohhhhhhhhhhh
btw the h60 is good too
2 minutes ago, josephaltareb said:
ohhhhhhhhhhh
exactly ;)
didnt mean to start a war guys ;)
Soooo, it didnt die?
I opened her up, took the "dead" fan off, and plugged it into a Sys Fan header and it worked no problem
replugged it into the cpu fan header it was originally plugged into and now it works like normal?
That's odd.  Well glad to hear it's working! :)
