Best Home Multiple-Acess Point Solution (on a budget)
Solved by Guest,
5 hours ago, dricha36 said:Just added floor plan. Would you also recommend the UAP-AC-LITE? Any devices that need fast speed have been hardwired - the WiFi is for browsing and basic streaming only. As such, it looks like the LITE offers the same features as the PRO just lower throughput - is that correct?
Also - any recommendations for an outdoor ubiquiti AP?
Lastly - Do you think these would provide enough range that I may only need two APs across the three floors?
Thanks for the help, man!
- The Lite's are basically a cheaper lower performance version - lower quality radio, they're not suitable for outdoor use like the Pro, use proprietary 24v PoE and in general aren't as good.
- Outdoor - can use UAP-AC-Pro's.
- No - you'd need minimum 1 per floor for good coverage.
