Hey guys,
I've noticed recently, that my card (G1 Gaming 970 from Gigabyte) uses only 50-60% of its power limit while under full load (gaming & rendering). Is this sth to worry about? Also, why does oc'ing show no effect at all at render times/frame rates? According to AB the core clock rises, but i get nothing in return in terms of framerates and it also uses only 50-60% of the power limit. Extra Voltage doesn't help at all.
Anybody an idea?
I'm using the latest drivers, AB 4.2, and Win 10, for render tests I used blender and for gaming, I used the internal benchmark from gta V
Thanks in advance!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/604152-problems-with-970-g1-gaming/
5 minutes ago, DarkRuskov said:
temps?
they are fine, about 30 degrees at idle (depending on how long the system's been running) and 60-70°C under load, doesn't get any hotter while applying an 100MHz OC, clock runs stock at solid 1367 MHz without any change over long gaming sessions
- Ryzen Build -
2x Dell UP2516D
It's using as much power as it needs to. If it used full power all the time then it would be incredibly inefficient.
If you want to experiment with power usage then try overclocking. additional voltage usually equates to more power usage.
1 minute ago, DarkRuskov said:
and it doesn't full load on stock in your benchmarks?
If it uses 60% of power limit then how much is the GPU usage itself? And for GTA your CPU might be bottlenecking thus the GPU showing no difference when overclocking
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
but it doesn't take it...
It does go to 100% usage, but it's actually not faster
- Ryzen Build -
2x Dell UP2516D
cpu isn't under full load, gpu usage is in every scenario at 100% or almost 100%
- Ryzen Build -
2x Dell UP2516D
TBH it could be a defective PSU if it cant deliver enough power, my power usage goes up to 105% or even 110% on extreme situations.
Honestly, it sounds fine. My G1 970 is overclocked and boosting to 1510mhz core and 8100mhz mem the only thing that even comes closest to using 100% power (out of it's 112% max) is The Witcher 3 and that hovers at around 85-90%. So your results sound fine. You can try benchmarking and comparing scores to regular G1 970s (something like Unigine Heaven at stock clock speeds you can expect a score in the ~1400 mark for Stock and ~1600 for max OC on Extreme preset at 1080p).
If your results are consistent with average G1 970 performance, then maybe the software you're using to render just doesn't really leverage the extra power, or you're running into a CPU bottleneck sooner. Additionally even a 10% bump in speed may help your framerate overall, but if you're not really looking for it, or you weren't hurting in the first place, it's not going to be a night and day scenario.
OS: W10 | MB: ASUS Sabertooth P67 | CPU: i7 2600k @ 4.6 | RAM: 2x8GB Corsair Vengeance 1600mhz | GPU: x2 MSI GTX 980 Gaming 4G | Storage: x2 WD CB 1TB, x1 WD CB 500GB | PSU: Corsair RM850x | Spare a moment for Night Theme Users:
I'm an erudite cave-dwelling Troglodyte
I frequent LinusTechTips past midnight
Dark backgrounds I crave
For my sun-seared red gaze
I'll molest you if you don't form your text right
I even get no performance boost in heaven or any other software.... that is the strange thing, I even see an performance decrease while oc'ed
- Ryzen Build -
2x Dell UP2516D
what for a 970 do you own?
- Ryzen Build -
2x Dell UP2516D
Msi gaming edition, I've overclocked it quite a bit.
But I'm talking about benchmarks where it goes so high, in games its usually below/around 80%
Are you actually monitoring your current clock speeds with any OSD or something in order to make sure it's not throttling? (thermals isn't always the issue, that's not what I'm getting at). In fact, there may be an angle to the PSU thing. The min requirement for the G1 970 is 550W, and yes, there's a good margin in those requirements, but you're on a 500W PSU, you're on 80+ Gold which is at best ~90% efficiency (so very crudely, you're maybe losing about 50 watts to heat at peak load) and you're using a more power hungry CPU. Not to mention various peripherals you may have on your system.
my system draws about 260W maxed out so there's much headroom  I guess. and my cpu uses 80W of them, only one hdd and 3 case fans + 1 cpu fan, one keyboard and one mouse, nothing else. Pretty basic setup. So why should these 50 W matter?
I monitored everything with afterburner (fan speeds, core clocks, memory clocks, temps, power usage,... ) and everythings stable even when rendering 2 full days long. everythings exact on the same level as when fresh restarted. Power usage fluctuates a bit because different scenes and so on while gaming, but that's it.
- Ryzen Build -
2x Dell UP2516D
just noticing it: the gpu hits the voltage limit but only runs at 1.206 V....
- Ryzen Build -
2x Dell UP2516D
@LooneyJuice: I can increase the voltage with +87 mV to 1.256, but then the OV Limit kicks in too (don't know what this is)
- Ryzen Build -
2x Dell UP2516D
I'm sorry, I know I'm being super pedantic, but by maxed out you mean max CPU and GPU power draw correct? Additionally the 80W TDP on your xeon is the posted TDP which can vary quite a bit depending on usage scenario, so are you calculating your power draw off posted TDP or actually monitoring it somehow? And also, could you give me some actual Heaven scores from your runs?
Additionally, the voltage is normal. GPU Boost throttles depending on thermals, power draw and voltage, and even in my case, on stock, after about 61-62 deg, t may throttle just a tiny bit from 1.225v to 1.205. That's perfectly normal. The best you can do even by maxing out the voltage offset btw is whatever your max voltage limit on the bios is which varies from case to case.
I monitored the power draw with some thing to plug in between wall socket and plug from the psu
And i messed up: i used valley but that shouldn't change the whole thing. I got around 58 fps, oc'ed it went down to 55
- Ryzen Build -
2x Dell UP2516D
Sounds fine, on stock with the extreme preset @ 1080p I was at 59.3. The small difference is attributed to my slightly higher actual stock boost clock of 1392mhz, which is completely luck of the draw. So unless something else is the bottleneck somehow, I can't really see an issue with your GPU. What's the most graphically intense title/software you can test on? Synthetic benchmarks don't always do the trick.
minecraft :D just kiddin
gta v, but here I saw no difference at all whether oc'ed or not
actually, I get the 1392 as soon as i increase the voltage
- Ryzen Build -
2x Dell UP2516D
Dude, dat minecraft.
Also, the way you can really tell whether it's doing anything for you (unless, like i said, something else is the bottleneck) is by saving both stock clocks and overclock in 2 custom profiles in AB and then assigning them to hotkeys. Find a fairly consistent scene somewhere in the game, start at stock, hit your hotkey and cycle to the OC preset to see what it's doing for you. Also, what's your overclock at which you're testing all this out?
tested it with fairly conservative 100MHz OC on core, didn't mess with the memory because slightly higher memory clock resulted in crashing during valley. as a result i get 1492 MHz. I'll try that tomorrow or so but now i might have to go to bed.
Thanks for your help, I let you know if i find anything
- Ryzen Build -
2x Dell UP2516D
Oki doke, that's when you may want to try your max voltage if you're not already doing so.
