Accidentally bought wireless router instead of wireless modem/router....
Solved by Arc_Jester,
6 hours ago, GeorgeGR said:
Downstream Upstream SNR Margin :15.6 7.0 db Line Attenuation :38.0 25.7 db Data Rate :4096 971 kbps
This would be a good one to get, I have one and has been working perfectly for months without a reset. https://www.amazon.com/TD-8616-Downstream-Bandwidth-Lightning-Protection/dp/B0034JSYZ2/ref=sr_1_1?ie=UTF8&qid=1464828998&sr=8-1&keywords=adsl+modem
