I NEED HELP
Solved by Enderman,
Just now, KSores said:then waht do i do when it asks for the key?
click "do this later"
as long as you had windows 10 on the PC previously it will activate itself when you connect to the internet
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
play_circle_filled
Latest From ShortCircuit:
