Here are my current ideas for my first build for gaming at 1440p:
PCPartPicker part list: http://uk.pcpartpicker.com/p/ZRXLr7
Price breakdown by merchant: http://uk.pcpartpicker.com/p/ZRXLr7/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£194.99 @ Amazon UK)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  (£22.46 @ Amazon UK)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  (£110.34 @ Amazon UK)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory  (£34.60 @ More Computers)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  (£34.98 @ Amazon UK)
Video Card: Asus GeForce GTX 970 4GB Video Card  (£259.98 @ Ebuyer)
Case: BitFenix Nova ATX Mid Tower Case  (£26.99 @ Novatech)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  (£49.99 @ Amazon UK)
Case Fan: ARCTIC Arctic F12 74.0 CFM 120mm  Fan  (£3.74 @ Amazon UK)
Total: £745.55
Generated by PCPartPicker 2016-05-23 20:28 BST+0100
What are people's opinions on it and does anyone have any advice to improve it? I am considering buying a second-hand GTX 970 in order to save some money.
I am also considering rack mounting it as I have a 42U rack that needs filling.
https://linustechtips.com/topic/600280-my-first-build-advice/
Total: £745.55
What´s your budget and goal?
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789487
My budget would preferably be under £750 and my goal is to have a machine to enable me to play the majority of all modern games at approx. 60fps at 1440p with good prospects for upgrading in the future.
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789507
get a used 390x because there going to drop when the 1070 arrives :)
Builds:
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789508
Total: £745.55
Hold up, only an SSD? No mass storage?
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789530
I would not recommend getting a 120GB SSD.
I have a 128GB SSD and after a complete install, I'm sitting at -50Gbs.
That's hardly enough room for any AAA game let alone anything at all.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789533
1 minute ago, Ottermad said:
390x looks a good idea but is it going to harder to cool I rack mount the pc?
nah not really, im not sure but look for a blower style cooler for it :)
Builds:
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789546
Ok thanks for the advice. Is it worth initially not running an SSD and just running a 1tb drive and then upgrading later possibly to an m.2?
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789551
I think getting a HDD now and an SSD later is a better option if you can't swing both.
SSD's are extremely nice to have but aren't what I'd consider a "necessity."
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789564
Total: £745.55
My 2 cents:
PCPartPicker part list: http://uk.pcpartpicker.com/p/6gf7Yr
Price breakdown by merchant: http://uk.pcpartpicker.com/p/6gf7Yr/by_merchant/
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.99 @ Novatech)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  (£85.44 @ Amazon UK)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£23.67 @ Amazon UK)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  (£29.99 @ Ebuyer)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  (£258.98 @ Ebuyer)
Case: Cooler Master N300 ATX Mid Tower Case  (£33.16 @ Amazon UK)
Power Supply: SeaSonic EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£70.99 @ Amazon UK)
Total: £735.43
Generated by PCPartPicker 2016-05-23 20:48 BST+0100
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789584
Nah, getting an SSD now means you don't have to go through a cloning/reinstall mess ever.
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789589
3 minutes ago, Starelementpoke said:
True, but that usually it means you have room for like 1 game after windows.
You could save the money you would have spent on that one game on a 1 TB HDD though. Just wait to play your games man, chill :P
What I might do in OP's situation is buy one or two less case fans for now and get a 240GB SSD like an SP550 for around $50 USD, that way he/she can actually hold off on buying a HDD and can play a couple games for the time being.
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789613
I am not really bothered by cloning and reinstalling so I think a HDD may be the way to go
You would have to re-download all of your games. All of them. Every program you had installed would have to be reinstalled. Several gigabytes of Windows updates would need to be done over. I would highly recommend holding off on getting a hard drive for now. You literally can plug one in and go with a hard drive later rather than spend an entire day getting your PC back to where it was prior by getting an SSD later. Trust me, I've done my fair share of OS reinstalls and having one SSD to start with will save you a lot of time.
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789621
6 minutes ago, Starelementpoke said:
My 2 cents:
Total: £735.43
Thank you for the suggestions. I may swap out the SSD for a HDD. Also have you got any suggestions for a motherboard with supports m.2 as that will probably be my first upgrade
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789629
Good point. Thank you.
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789663
http://uk.pcpartpicker.com/part/msi-motherboard-z170apro
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789664
My comment was between the 120gb SSD and the 1TB drive.
If he'll move up to the 250gb SSD now, I would go that route as well.
Simple math gives him ~ 180gb which is plenty for two/three large games a host of smaller ones..
https://linustechtips.com/topic/600280-my-first-build-advice/#findComment-7789665
