4 minutes ago, Haydenp10 said:
So I believe the issue is with my CPU
But I have
I5 - 4460
GTX 970 Gigabyte 3X Windforce
It's like my performance is really good then it drops all of a sudden
Have you thought about thermal throttling? Check your CPU temps. It might be that.
https://linustechtips.com/topic/598799-problems-with-pc/#findComment-7774252
1 hour ago, Haydenp10 said:
I5 - 4460
1 hour ago, ItsMinJunLol said:
...thermal throttling? Check your CPU temps...
1 hour ago, fixitnow said:
...HWmonitor. If temps are less than 50°C...
My 4790K doesn't throttle until 100°C.  With the 212 Evo, I usually see temps in the 50s to low 60s under load at 4.2-4.45 GHz.  (I only see 100°C in Prime95 28.7 small FFT, and usually only when several months of dust has accumulated.)
https://linustechtips.com/topic/598799-problems-with-pc/#findComment-7774606
Performance in what games exactly, also what drivers are you running. And what are your gpu temps
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/598799-problems-with-pc/#findComment-7775815
