Can't get microphone to work via audio port
10 minutes ago, OAcesync said:My Realtek HD audio manager prompts to tell me what device was plugged in, if I pick headphones, I can hear audio perfectly fine but microphone doesn't register on my PC what so ever
Does the motherboard/case have two plugs? In that case you would need to buy an adapter that will split the audio from the mic and route them to the appropriate plugs. Most computers have one plug for audio output and one for audio input. Phone earbuds are a tad different and have an extra band on the plug for the mic, while computer ones generally don't have that band. So they are physically incompatble. But I got a cheap $2 splitter off amazon and that worked fine. Just make sure to plug the headphone jack and mic plugs into the appropriate places. Here is one that I found, just make sure that yours looks like it:
