So.. missing a day in Geometry or any math class is not fun. There are 3 types of problems on this paper that I either want help/answers to similar example problems to help me going. There are an extra 10 from the 3 I am asking, so not trying to get you to do my H.W.
1. Write an equation for the circle that satisfies each set of conditions.
center (-4,2), radius 8 units.
2. endpoints of a diameter at (-2, -9) and (0,-5)
and last one
Find the center of the radius of each circle. Then graph it. I can do the graphing part.
(x+3)^2 + y^2 = 16
Thank you.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/597669-geometry-help/
I tend to prefer to work with circles...
π and 360° and 180° are things that are used in circles...
So umm if a ♂ likes ♂s and that's okay. Just like I'm a ♂ and like ♂s... And if a ♀ likes ♀s that's cool too. If a ♂ likes ♀s that's cool too and if a ♀ likes ♂s that's also cool...
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/597669-geometry-help/#findComment-7761389
No idea what you are trying to say.
https://linustechtips.com/topic/597669-geometry-help/#findComment-7761444
lol wtf
https://linustechtips.com/topic/597669-geometry-help/#findComment-7761448
I don't know either... lol. I wanted to answer those questions but they're kinda awkward so I just wrote that... I think that's because you're graphing them on like a grid and like that kinda stuff was annoying but like almost anything else with circles, spheres and hemispheres is fine.
So for the first question, I think the center is probably either -4 or 2. If I recall correctly deciding where the center of the circle was up to your discretion.
5 minutes ago, No said:
lol wtf
Idk
https://linustechtips.com/topic/597669-geometry-help/#findComment-7761475
Circle equation is
(X-ox)^2+(Y-oy)^2=R^2
Where ox and oy is the coordinates of the middle of tge circle.
1.) Using the above equation and substituting -4 2 and a radius 8 we get,
(X+4)^2+(Y-2)^2=8^2
2.) Find the middle point between the end points of the diameter.  That is the middle of the circle.  Then find the radius.
3.) Use the equation in number 1
https://linustechtips.com/topic/597669-geometry-help/#findComment-7761627
