Just now, Simbios007 said:
hello
i would like to know which is the best cooler under Rs5000 (75$)
air or water
suggestions required
if you want it to be silent: bequiet dark rock 3
for high overclocking: Enermax Liqmax II 240
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/596348-air-cooling-under-budget/#findComment-7747768
3 minutes ago, Simbios007 said:
hello
air or water
inb4 "HYPER 212EVO !!!!!!!!!"
The Noctua NH-D14, Phanteks PH-TC14PE and LEPA AquaChanger 240 (basically an Enermax LiqMax II 240) are all right around the $75 USD mark, and all perform well. If it were me, I'd go for the Noctua for price/performance and reliability.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/596348-air-cooling-under-budget/#findComment-7747784
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/596348-air-cooling-under-budget/#findComment-7747804
What are you cooling? Can you link us to where you're shopping?
https://linustechtips.com/topic/596348-air-cooling-under-budget/#findComment-7754012
3 hours ago, Simbios007 said:
Im cooling my amd fx6300
Im from india i don't have options as much as you do
I use amazon
Hyper 212x is good: http://www.amazon.in/Cooler-Master-Hyper-Intel-Processor/dp/B00D2LZ3AG/ref=sr_1_1?s=computers&ie=UTF8&qid=1463496654&sr=1-1&keywords=hyper+212
https://linustechtips.com/topic/596348-air-cooling-under-budget/#findComment-7757805
