so i have a netgear x6 nighthawk tri band router with a apple airport extream (5 gen) extending the 2.4ghz and i have them both under the same network name and if im upstairs by the nighthawk i get full bars but when i go to the far side in the basement where my airport extreme is it doesn't auto switch but when im in the basement and reconnect it switches. is their a way for it to auto connect to the best signal where ever im at in the house with out doing a relog on my phone
https://linustechtips.com/topic/595129-need-networking-help/
It's for this reason I don't keep the same name on network extensions/access points etc, so that I can check which it is using and just switch if I need to... it's frustrating for everyone. Not only that, but it's more frustrating to have your family saying "why is this going so slow" etc etc.... changed and no more moaning, if they don't switch to the correct access point/ext then it's tough $$%% :P
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/595129-need-networking-help/#findComment-7736111
is their a setting or something i could change?
https://linustechtips.com/topic/595129-need-networking-help/#findComment-7736132
A setting on your airport extreme you mean?  I couldn't tell you, have never owned one, but I would assume there is a setting to change the name of the SSID somewhere if that's what you mean?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/595129-need-networking-help/#findComment-7738877
