Cooler Master Cosmos SE released
Contained within the desirable exterior of the COSMOS SE is the support for truly exceptional system builds. COSMOS SE comes capable of supporting up to 8 fans with four being preinstalled. Two 120mm blue LED fans in the front with LED on/off control, one 140mm fan in the top, and one 120mm fan in the rear to provide strategically placed cooling for all of a user's systems components. Superior liquid cooling support is built in for 120, 240, 280, and 360mm radiators with users being able to install a 120, 280, and a 360mm radiator all at once.
https://linustechtips.com/topic/59441-cooler-master-cosmos-se-released/
SURPRISE no one cares, cosmos is past its expiring date.
Listen if you care.
You cared enough to click the thread and post a comment.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
That's the most incorrect thing I've read today and I've seen a lot.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
Sorry i dont remember posting that comment, this is great it seems someone is on my account, i dont mind the cosmos, its not my favourite massive tower but its definitely not the worst.
Listen if you care.
Not a bad looking case but it would look much better without the handle bars at top and bottom in my opinion :P
I don't think it would be considered a Cosmos without those. Although I am quite bored with the Cosmos design, the original Cosmos 1000 looked awesome (although it was terrible to build in) and it barely changed with most changes being negative with every iteration.
