Not sure exactly where to put this thread..
#1 Can I use it as a boot drive? For example could I put something like DBAN on it and save myself a USB.
#2 Can I plug it into a PC and control it? For example if I made a remote for my television could I send commands from my PC.
#3 Kind of going along with question 2, could I plug it into my PC and have it do something? Like organize files, or use it as some kind of adware cleaner?
https://linustechtips.com/topic/593876-raspberry-pi-questions/
yes you can do all of those things
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/593876-raspberry-pi-questions/#findComment-7722399
4 minutes ago, Nater said:
you can control it over the network via ssh.
not sure about #1 and #3
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/593876-raspberry-pi-questions/#findComment-7722402
#1 Network boot drive.
#2 Socket library with UI on pc or remote access of some sort to pi.
#3 Certainly doable but you would need to put a lot of thought into an implementation as i doubt there will be anything that exists that can compile for the pi.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/593876-raspberry-pi-questions/#findComment-7722580
  • 2 weeks later...
#1 Not sure
#2 Yeah you could, but i think it would be a lot harder than just send a command over WiFi to it, to use it via PC OS you would need a robust driver. To Send it over network and/or Bluetooth you only need a program running on the Pi and on the PC.
Aside from that you can connect via SSH and GUI too, there are tutorials on the web for that.
#3 Organize files is possible, just mount the folders that you want to organize in the Pi and make a program to organize things as you want.
https://linustechtips.com/topic/593876-raspberry-pi-questions/#findComment-7764230
