Best Fan Placement for NZXT H440
Frankk
I have 4x 120mm fans. 1x 140mm. I also have a Corsair H60. I want to have the best air pressure possible.
1 minute ago, Aytex said:
3 on front
put rad on the exhaust
Intake? what about the 140mm?
When you say you want to have the best possible air pressure possible I'm going to assume you're talking about having positive air pressure correct?
If that's the case then do the 3 120's in the front and then just do the H60 acting as the rear exhaust and save the 140 for something else.
