Headphone issue
Go to solution Solved by Dackzy,
5 minutes ago, Erupi said:
On my old headphone, both side works fine. This new one needs me to input the USB cord attached on the headphone as well for both side to work. Based on the box, the USB only used for the LED lights.
The usb must provide extra power to the driver part then.
Hello LTT forum. I would like an assistance about new headphones i bought recently.
Currently my headphone has a problem. When I insert audio jack alone, only right side have sounds while left doesn't, I had to plug in the USB (Intended for the light on headphone) and then both side outputs nicely. However when there's no audio running, the right side of the headphone has a small annoying static sound.
Is there something wrong with the jack since i need to plug the USB too? Here is my PC specs and current headphone I am using
OS : Windows 10
CPU Type : QuadCore AMD Trinity, 3200 MHz
GPU : Nvidia GeForce GTX 950
Sound Driver : Realtek High Definition Audio Controller.
Headphone : Sonicgear X-Craft 2000
https://linustechtips.com/topic/591658-headphone-issue/
Something is wrong with you headphones that is for sure when you say you have static sound when no sound is playing.
I also think you have a cord that is not connected to your onboard sound, unless both sides work on other hadphones or headsets.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/591658-headphone-issue/#findComment-7699224
https://linustechtips.com/topic/591658-headphone-issue/#findComment-7699258
1 minute ago, Erupi said:
It says on the box that says "Total Number of Drivers built-in : 2".
I suppose it does used for extra power. Thanks everyone.
you can always send them back if you don't want the static noise and buy something else.
https://linustechtips.com/topic/591658-headphone-issue/#findComment-7699316
