So after reading up, people are suggesting there's no point in upgrading to an i7, if you're only planning on gaming.
My current Motherboard: Gigabyte GA-H1M-D2V (apparently I need an upgrade) for it to compatible with the CPU or something?
I have a few questions:
Question #1: What motherboard shall I buy? and what is the true purpose of a motherboard.
Question #2: Will I have to buy new RAM?
Question #3: If I ever decided to overclock, would I need to buy a new PSU? or is 500W enough?
Question #4: Do you think this is a good build? (btw I also have a 1TB HDD but it's unplugged within my system - idk how).
https://linustechtips.com/topic/591556-a-few-more-questions/
3
The mobo depends on what you need and/or want. Preferably get a gaming overclocking edition mobo.
What ram have you currently got?
There's no need to upgrade as 500W is more than enough.
Yes, it looks good. (Some super enthusiasts might pick out some irrelevant stuff and argue it.)
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/591556-a-few-more-questions/#findComment-7698058
I didn't actually know Motherboards impacted your computer as much as you're suggesting. I'll do a little research on them. I've got 8GB of DDR3 @ 1600 (I think).
https://linustechtips.com/topic/591556-a-few-more-questions/#findComment-7698064
The ram seems all good.
Overclocking your CPU has 3 main factors:
1. CPU type
2. Power supply
3. Motherboard
That's because if you get a non-overclocking mobo you most likely won't be able to achieve a stable OC.
Desktop
LAPTOP
https://linustechtips.com/topic/591556-a-few-more-questions/#findComment-7698071
1. CPU type
2. Power supply
3. Motherboard
Any recommendations for a Mobo to go with the CPU? I don't care too much about OC.
https://linustechtips.com/topic/591556-a-few-more-questions/#findComment-7698078
i know this not related to what your asking but ppl already answered your question
so i would recomend you get a i5 660k
https://linustechtips.com/topic/591556-a-few-more-questions/#findComment-7698085
