Nexus 5x/6p
Samsung S7/S7 Edge/Note 5
Moto X / Drod Maxx 2
You can go to your carriers website, or order it off another website.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7692154
I am not sure of the best android phone. But i am pretty sure you can purchase a phone off of your carriers website. Or off of the website of the company that makes the phone and just transfers the service over. (at least thats what i did with my iphone)
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7692174
It really depends on what you want a phone to have. For ex. If you want a good camera then go for the S7. There are other phones like the HTC 10, and LG G5 (if you don't mind plastic feeling metal). Just note that it's still only may, and a bunch of phones like the Note 6 will come around fall and winter.
-Kevin-
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7692179
18 minutes ago, djdwosk97 said:
Nexus 5x/6p
I'd add to that...
  • Nexus 5X and 6P
  • Samsung Galaxy S7/S7 Edge and Note 5
  • Droid Turbo 2
  • LG G5
  • HTC 10
  • Moto X Style
So I only added two or three phones. Whatever.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7692195
Galaxy S7 Edge / S7 ---- HTC 10 (or other way around. depends on which features you weight stronger)
Nexus 6p (i rate this BELOW this years generation. S7 (Edge) just Nailed so hard this year... Even LG G5 looks like an average phone with a bad built quality in comparison (well.. it has a bad built quality, and i would not recommend the LG G5).
If you do NOT Life in China, or USA, and your Region has the Exynos model of the Galaxy S7 ( Edge), then definitely S7 (Edge).
The Exynos chip is MUCH more efficient, than the Snapdragon 820 chip. The s7 with Exynos chip can last like 20-30% longer than the Snapdragon version. That's a huge Plus.
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7696162
On 5/4/2016 at 5:38 PM, djdwosk97 said:
Nexus 5x/6p
No Moto X Pure, LG G5 or HTC 10?
Also,
http://www.androidcentral.com/best-android-phones
http://www.androidauthority.com/best-android-phones-568001/
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/591038-best-android-phones/#findComment-7717427
