Which case fan should I get?
Tweed
Phanteks PH-F120SP or Fractal Design H12-BK
They will be for the bottom of my case, InWin 805, on top of dust filter and possibly right next to a hard drive cage (maybe).
Really doesn't matter, I would just go with whichever you like the looks of better.
My only input is that I have a couple Phanteks fans and they're very quiet, at max speed there's a whoosh of air flowing and a very slight hum
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
