1 minute ago, awesomes8wc3 said:
my green drive also makes a slight buzzing sound when it starts. you should be backing up anyway.
i have 2 green drive same type one buzzes one does not and it's not s light buzz it's the loudest thing at startup can hear it above fans and pump startup
https://linustechtips.com/topic/588917-hard-drive-failing/#findComment-7668916
Might be a good idea to contact WD then.
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
https://linustechtips.com/topic/588917-hard-drive-failing/#findComment-7668920
if you're worried, download crystal disk info and see what it says about the drive
i recommend you backup the drive if your files are important
and run this test from WD if crystal disk info says the drive isnt healthy
http://products.wdc.com/support/kb.ashx?id=Yn3Rcx
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/588917-hard-drive-failing/#findComment-7668935
23 minutes ago, carrmatthew123 said:
 should i replace the drive or is it fine
No idea ,but a loud buzz should be taken as a portent of doom, Back-up anyway (especially as it contains "important documents").
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/588917-hard-drive-failing/#findComment-7668936
Might be a good idea to backup your files incase it fails, contact WD Nonetheless.
                            500 Posts achieved 29/4/16 9:13PM
i7 980x Power! BeamnDrivionothbesgameComicSans
“I was the rebellious one.” - Maxene Andrews
Damn that's a nice hair flick 1981 Simon LeBon!
"Nothing gets you going like a juicy pussy!" - ashens
"what sorry blender isn't that what you make smoothe?" - pathole
"Yeah, well i'm a member of the waffen ss who lives with hitler in the bunker And i like modern music!" - Hans krebs loves fish
"We won world war 2 for a reason" - ironic shitposting is still shitposting
"Fight shooting game with pretty girls" - megami strike 1943
"You've got wood in an evo" - moog
"oxygofishafacematerialsotosis" - linus
"Vehicle stimulator" - crappy russian mod site
"The power table" - Nerdcubed
"Nuclear spaghetti" - ashens
FRANKIE SAYS RELAX!!!!
https://linustechtips.com/topic/588917-hard-drive-failing/#findComment-7668963
